How do I connect? I just purchased to 999 and AQ send is trying to connect. I have an android tablet
geposted Tue 02 Jan 24 @ 1:36 am
VirtualDJ requires full windows or macOS
https://virtualdj.com/wiki/Minimum+system+requirements.html
unless you're talking about the remote app? in which case if you have a windows computer you will need to make sure Bonjour is installed on it to connect.
geposted Tue 02 Jan 24 @ 3:08 am
