Hi guys,
I want report something strange I discovered when using the stem 2.0 split separation. Check out this video I made:
In short, some of the songs I mixed and recorded have an occasional beat glitch. At first, I thought this issue was something that had to do with the recording process, but today I wanted to dig in into this, and noticed that when I split the song using the STEM 2.0 separation, a clicking (beat glitch) appears. To me the song should sound the same by playing it both ways split/normal. This is an issue that is amplified when recording mixes, maybe when doing live presentations is not so obvious.... But I reckon this should not happen either way.
Any ideas or suggestion?
Thanks
geposted Wed 03 Jan 24 @ 2:25 am
Possibly similar/same as reported in this thread:
https://virtualdj.com/forums/249996/VirtualDJ_Technical_Support/Pop_Click_in_the__2_0_Kick_Stem__particularly_House_genres______VDJ_2023.html
Would love to know if there is progress in the works :)
geposted Wed 03 Jan 24 @ 6:07 am
Thanks, exactly the same issue !
geposted Wed 03 Jan 24 @ 12:58 pm
