I'm trying to figure out a easy way to select the effects 1-3 using the controller. I wanna use the knob though to adjust the effects. I usually just remove a effect from slot one on deck one then just add another effect. What's a easier way to do this? I'm talking about the Level/ Depth knob on the controller.
geposted Fri 05 Jan 24 @ 10:57 pm
