Does VDJ change the resolution on for the slideshow VFX when in Karaoke mode? I have my karaoke setting to video output for displaying images in between singers and the images are blurry. If I turnoff karaoke mode the images in the slideshow are much clearer. Difference is definitely noticeable on a 55" external screen. Is there a solution or work around for this?
geposted Mon 15 Jan 24 @ 2:41 pm
It should be the same. Could you make a screenshot of both to compare?
geposted Tue 16 Jan 24 @ 4:30 am
Just to update.. it seems to be when I turn on the Screen overlays to list the upcoming singers AND the next song is loaded in the deck.. if you unload (eject) the song from the deck the resolution clears up and looks good.
geposted Thu 18 Jan 24 @ 2:28 pm
