I've been messing around with the stems but my laptop i think is kinda slow for it. I just bought this laptop couple years ago. Is there something in the Virtual dj settings I can go in and adjust? I can't afford another laptop right now. If you guys would suggest a cheap fast laptop that does great with this software which one would it be? It can be a Walmart laptop I don't care. I'm gonna have to start saving for a new one
geposted Thu 18 Jan 24 @ 2:45 pm
If you don't have the CUDA cores and 6+ GB of VRAM there's not much you can do, using lower fidelity stems is pretty much it, or preprocessing stems.
geposted Thu 18 Jan 24 @ 3:04 pm
Nothing wiith the dedicated graphics required for Stems 2.0 will be "cheap".
I just bought a machine perfect for realtime stems (processing at 41x) but it was $3200 with a 40% discount.
geposted Thu 18 Jan 24 @ 3:08 pm
Ok cool I'm gonna have to look into something different.
geposted Sun 21 Jan 24 @ 5:45 pm
