Topic: Mapping for APC mini mk2
Hey guys, I can not find a solution anywhere, not even the tech support of both companies. So I will try my best here.
I figured out how to pace jingles on each button through the mapping in Virtual DJ.
What I would love to happen is:
When I hit a jingles it starts and when I hit it again, it fades out. Right now it just stops.
The other thing, I would like to color code different lines in different colors, so I can see what jingles are the happy jingles and what jingles are the sad jingles.
And now the icing on the top :)
All solid colors, except the one playing, that should be flashing while playing.
I know I am asking a lot. I am just the little button pusher for fun. No big time DJ or programer.
So help on any on those topics would be amazing.
Thanks in advance :) :)
geposted Fri 19 Jan 24 @ 3:53 pm
colours are easy, look at how sampler pad LEDs are mapped.
Fade out is a bit more involved
query if pad is playing, if not start, if yes start a rsi script to lower the volume and every repeat query against a low level, if matches condition, stop the pad, then restore the volume.
I tried to copy and paste from original mapping in regards to the color coding, but then the button stops working
