How do I tell VDJ to ignore network shares on Mac?
I'm getting reamed by my admins because VDJ is scanning any network drive I'm connected to and creating databases where it shouldn't.
geposted Sun 21 Jan 24 @ 7:29 pm
Whack this in to Google and the first post is your answer :)
ignore drives mac site:virtualdj.com
Spoiler .... It only works on Windows.
geposted Sun 21 Jan 24 @ 7:31 pm
Yes indeed, this was my second stop after trying the IgnoreDrives setting and it doing absolutely nothing, haha.
I really need a solution for this or they will quite literally force me to switch to Serato.
geposted Sun 21 Jan 24 @ 7:39 pm
It does work on mac as well.
Just enter the full drive path
( /Volumes/MyDrive for example)
geposted Mon 22 Jan 24 @ 4:26 am
Thank you for the clarification Adion. Perhaps it's not working because I'm not separating multiple paths properly. I have the following shares that need to be ignored:
/Volumes/192.168.0.100/Users
/Volumes/192.168.0.101/90's, 2000's, 2010's
/Volumes/RDSServ/Logging
How would I put all three of those paths in the field?
geposted Mon 22 Jan 24 @ 5:33 am
Check in Local Music/Drives
These are the paths vdj considers drives.
There's no option to ignore folders, but since it's only 3,you could add them as favorites and occasionally right click and remove from search db those
geposted Mon 22 Jan 24 @ 5:54 am
