Topic: Can't Delete Tracks
All of a sudden, I can’t delete files. I highlight them, right-click FILE OPERATIONS>DELETE but nothing happens. I’ve gone in and checked the drive, root folders down to the file and nothing shows “Locked.” If I check Tag Editor, it shows is as a missing file. Suggestions? (I have tried restarting the program & computer)
MacBook Pro. Latest OS- Sonoma 14.1.1 & latest VDJ v2023_b7831
Thanks.
geposted Fri 26 Jan 24 @ 3:13 pm
If the files are missing, then there's nothing to delete.
they still show up in VDJ as normal (non-missing) files
Clean your database then. If the tag editor says they're missing then they're missing. If nothing happens when you try to delete, they're already deleted.
