keep saying virtualdj is not responding
geposted Sat 03 Feb 24 @ 8:46 pm
have you checked your Hosts file?
Can you connect to the net otherwise.. say doing a speed test?
Quote :
Try this tool ...
For PC:
https://www.dropbox.com/s/karz2iau751rxmj/FixVirtualDJHosts.exe?dl=0
For Mac:
https://www.dropbox.com/s/nc837lqn2jnecgu/Fix%20VirtualDJ%20Hosts%20Mac.zip?dl=0
If the tool doesn't work, try to edit the hosts file manually and remove the virtualdj entries
https://support.rackspace.com/how-to/modify-your-hosts-file/
For PC:
For Mac:
geposted Sat 03 Feb 24 @ 9:47 pm
