Hi guys having problems with audio splitter works great when i select the filter effect above crossfader it kills the headphone mono channel all other effects work fine or if off works fine too any reason this will disable the mono channel of the headphones as favourite fader effect thanks
geposted Sat 03 Feb 24 @ 10:09 pm
double tap alt to make it latch
geposted Sat 03 Feb 24 @ 10:13 pm
Thanks that worked excuse my newbieness lol
geposted Sat 03 Feb 24 @ 10:15 pm
the alt thing isn't a hard requirement you can just map direct to keys if you want.
The whole popup keyboard is like an entry point
geposted Sat 03 Feb 24 @ 10:39 pm
thanks yeah want it just to be active with out pushing alt really
geposted Sat 03 Feb 24 @ 10:47 pm
