Trying to move away from the sync button.
However, it is very useful to press it to match the bpms before pressing play on the new track.
But when I do, then when I press play it does some type of sync.
I would like to map the sync button to only match the bpm from the track that's being played but not quantise it when I press play on the new one.
Makes sense?
Any help will be appreciated!
Makes sense?
geposted Wed 07 Feb 24 @ 10:47 am
That sound like smart play or sync on play or something like that
The regular sync button only aligns the BPMs if pressed when the track is paused/cued
Here is a quick run-trough of the different auto options that you may want to look at:
geposted Wed 07 Feb 24 @ 10:51 am
Thank you for pointing me on the right direction! Very informative video!
geposted Fri 09 Feb 24 @ 9:00 pm
