Hello, I had no issues until late December '23. Currently I am able to select the effect to turn on or off whichever channel I want it on, with FX Select, but now the level/depth(STR) knob effects both channel, regardless of which one is selected. I have tried uninstalling VDJ and re installing different versions, also tried installing the DDJ drivers on my mac. No dice. If anyone knows a solution, that would be greatly appreciated.
For reference: the knob I am referring to is #32
geposted Tue 20 Feb 24 @ 9:08 pm
deck left var 'DDJFLX4FX' ? deck right var 'DDJFLX4FX' ? deck all effect_slider 1 : deck left effect_slider 1 : deck right var 'DDJFLX4FX' ? deck right effect_slider 1
change the script for FX_LEVEL to ^that^
or this [same result just less typing]
( deck left var 'DDJFLX4FX' ? deck left effect_slider 1 : ) & ( deck right var 'DDJFLX4FX' ? deck right effect_slider 1 : )
geposted Tue 20 Feb 24 @ 9:17 pm
