Topic: Songs skipping
PC Specs:
ASUS ROG Strix Scar 15 (2022) NVIDIA GeForce RTX 3070 Ti,
Intel Core i9 12900H, 16GB DDR5, 1TB SSD, Windows 11 Home
Controller: Denon MC6000mk2
I have been noticing especially since last year that songs are sometimes skipping while playing. Its not that noticebale but it does happen. I wanna note that i play mp3s and also mp4s. It doesnt happen with every song but in a night it will happen every few songs. Any idea what this is? i tried deleting my settings.xml file and using the default one with the default skin and it still happens there as well. Nothing else running on this pc. Also im not connected to hdmi when this happens.
geposted Mon 26 Feb 24 @ 1:28 am
Assuming you're using the Denon ASIO driver, what's your buffer size set to? Have you tried adjusting it?
Have you run a latency checker on your system?
i dont know how to check any of that. I got a newer computer so ill test it out this week with the new computer. could be some other app interfering.
That's what Google is for. You can't just expect something to magically fix itself without you putting in a bit of effort.
