Topic: Make a Different Skin as Default
How do I make a specific skin as "Default?" I select my skin (Virtual 8 Old Default), but every time I close VDJ, if changes back to the factory original default skin.
It's driving me crazy.
geposted Mon 26 Feb 24 @ 6:55 pm
That should definately not happen, unless for some reason your settings.xml file is set as read only.
Are you able to save other changes on settings ?
Or do they also revert back ?
