Topic: Stems Split?
Hi, been playing around with splitting a specific stem to another deck.
At the moment, it keeps the stem on the active deck (deck 1) and the rest of the song gets sent to the "inactive" deck (deck 3).
I would like to ask if someone could tweak it to do the opposite:
Send the stem to the deck thats not active (deck 3) and keep the rest ond deck 1.
Here's the script:
leftdeck ? stems_split ? on & deck 1 stems_split : off & deck 1 stems_split : stems_split ? on & deck 2 stems_split : off & deck 2 stems_split :
I was playing around and couldnt figure it out.
Many thanks!
geposted Tue 27 Feb 24 @ 11:50 am
Replace all stems_split with stems_split 'vocal' in your script
geposted Tue 27 Feb 24 @ 1:05 pm
YES!
Thank you!!
geposted Tue 27 Feb 24 @ 1:38 pm
