Topic: Some problems on Mac with High Sierra
Hi everyone,
I noticed that lately, after some updates there are problems on Mac with High Sierra (I don't know with later versions).
The mobius colorfx work badly, the colorfx knob moves two sliders of the effect simultaneously, the first and the second.
When Virtual DJ is opened, the LEDs of controllers such as RZ and RZX have two small discharges and flash for 1 second, after which the colorfx filter button is activated by itself.
The DDJ-1000 display does not update the effect_beats correctly, by rotating the affect selector you can notice how you often have to first move to the previous (or next) effect to see the correct values.
The LEDs of the DDJ-XP2 when opening Virtual DJ often do not respond to the default commands and colors, the same problem that the XP1 had which, thanks to my report and tests, was solved a few years ago.
Everything I listed with the same controllers, same usb cables, same power socket on PC does not happen and everything works fine. Can anyone confirm any of what I've listed? I am possibly available to do any tests and give my help to solve these problems. Thank you.
geposted Wed 28 Feb 24 @ 2:29 am
