So I was comparing how the S11 handles stems compared to my old Z2. I noticed when decreasing the MID EQ trim knob on my Z2 it lowers the Melody or bass line and keeps the beat and vocals. On my S11 it seems to have some EQ on top of the stem isolation when using EZRemix for the EQ Mode . Is there anyway to make the S11 behave like my Z2 does? TIA
EDIT On the S11 the drums sound filtered compared to my Z2 when decreasing the MID trim
EDIT: found my answer
https://virtualdj.com/manuals/hardware/pioneer/djms11/layout/eq.html
"The entire Equalizer, Filter and Master section of the unit is Hardware operated. The VirtualDJ Equalizer (including Stems) and Filter are not used, even thought the knobs on the GUI follow the actual ones (fake mode)"
geposted Fri 01 Mar 24 @ 12:26 am
