Topic: more than one broadcast address
Is there a way to add a different address in the broadcast table but keep existing one. I only want to broadcast to one server but sometimes I have to switch to different servers and I dont want have to type that out each and everytime. Right now it says default but i dont see a place to add or save a new one
geposted Sat 02 Mar 24 @ 9:00 pm
Yes
type the name you want to call the current Broadcast setting, then click the "save icon" to the right.
then configure the Broadcast settings to your second, (or third) configuration w a different name.. then again click the "save icon"
switch between configurations with the drop down "Config", menu
Note: can have any number of configurations saved.
(and of course the [ X ] deletes the current configuration)
Thank you so much for the help!! Much appreciated!
