I would like to add a bar counter to a waveform on a existing skin similar to the bar counter on the default skin. Does anyone know how to accomplish this? Thanks
geposted Sun 17 Mar 24 @ 5:24 am
You don't mention the name of the skin that you want to modify, but the easiest way is to ask the skin author to add a bar counter.
Another way is to take a look at the code of the default skin, then copy and paste it into an appropriate place in the other skin. You may need to change the size and/or location, but it's not rocket science.
Yet another option is to ask one of the forum regulars to do it for you, which may involve a small fee.
geposted Sun 17 Mar 24 @ 5:36 pm
you'll find the placement in the default:pro skin around line 4671.
geposted Sun 17 Mar 24 @ 5:54 pm
I would like to update Project X Slider skin. I could not locate the html syntax in the default skin for the bar counter. Any help?
geposted Mon 18 Mar 24 @ 6:12 pm
