Topic: Echo effect problem
I have got a problem with the echo effect. After turning it on, the sound from the channel stops coming to the master output. At the same time, it continues to play on the line, and I can listen it in headphones. This happens to both the left and right decks. However, there is no such problem with any other effect, everything works fine. I tried restarting the program, tried replacing the native_Echo.ini file, nothing helps. Perhaps this started after installing the extension "Brake FX" from extensions menu - pads. I removed this extension, but it didn't help. Can anyone tell me what the problem is?
geposted Sat 23 Mar 24 @ 2:34 am
Solved. In echo options was active "mute source"
geposted Sat 23 Mar 24 @ 3:54 am
