Topic: VDJ 24
issues with VDJ 24 closing down when trying to view/ load playlist . This only happens when trying to use two certain lists from playlists, all other lists load with no issues .
should reinstall VDJ 23 ?
geposted Mon 25 Mar 24 @ 12:33 pm
No, you should explain what's happening in more detail so the dev team can fix the issue.
geposted Mon 25 Mar 24 @ 1:23 pm
Happens all the times with the specific Playlists ? Is it m3u, or some other "special" playlists from Crates/Rekordbox etc ?
If its m3u, can you open with some Text Editor and post the content here from one of them ?
geposted Mon 25 Mar 24 @ 2:18 pm
Download VDJ 24 All my 30 playlists and other info moved over no problems when I click on certain lists they do not open to view or play and cause VDJ closes down and I have to restart VDJ.
It is always the same 4 lists that cause the VDJ to close down.
The lists are no different to the other lists I have . all music from Tidal downloads and plays just as it should from the list stored VDJ.
geposted Mon 25 Mar 24 @ 6:49 pm
can you post here one of the lists that is causing the issue?
geposted Mon 25 Mar 24 @ 7:36 pm
