Topic: Video goes green
hey there; i've seen this a couple of times now where the video output (and in the monitor screen within vdj) just goes all green for some reason. seems to only happen intermittently lately..maybe an issue with latest upgrades? i've also had some weird freezing/crashes over the last 5 days too.
geposted Mon 25 Mar 24 @ 2:44 pm
Would help if you said which VDJ version you are using and what the crashes actually were?
Also check your graphics card drivers are up to date.
geposted Mon 25 Mar 24 @ 2:51 pm
sorry..it's the latest version b0819. running on a m2 macbook pro.
geposted Mon 25 Mar 24 @ 2:55 pm
Thanks - what encoding is used on the video files that are going green?
geposted Mon 25 Mar 24 @ 2:58 pm
i just tried the same video file and the green doesn't appear this time. i wonder then if it had anything to do with system overload potentially. i'm streaming on twitch using obs too, and i know that depending on how much i'm doing with overlays and similar elements through obs it can cause issues so i've really pared down that end of things. but anyway, i'm running video through obs with the output settings on the attached
geposted Mon 25 Mar 24 @ 3:39 pm
