Hi,
would it be possible in one of the future versions to also allow syncing of all VDJ Settings? So that the VDJ instance that I use on my "preparation" laptop will always be the same like on my "live" laptop?
Especially changed settings and custom controller mappings should then get synced automatically into the live laptop (one directional would be sufficient).
Thanks
Thanks
geposted Mon 01 Apr 24 @ 4:54 pm
Probably not wise to sync settings.xml as it can be machine specific. For example of you prepare stems on a powerful desktop and only use precomputed ones on your gig machine.
geposted Mon 01 Apr 24 @ 4:57 pm
