Topic: Karaoke via Onedrive using 2024
new clouddrive function in 2024
Hi All, I have synced with onedrive to see if i can save storage on computer,
in doing so I have looked into obtaining the karaoke files via the new setup (online folders via clouddrive)
however all that shows when searching for karaoke files is the mp3 and does not play the .cdg
why is this?
does anyone else have same issue?
Note all my karaoke is on onedrive and i have that synced as "always on my computer" this has worked for me for many years prior to 2024 and still works,
****this above question is only related to using the new clouddrive function****
geposted Thu 04 Apr 24 @ 6:23 pm
the current version will only upload the main file, in this case the .mp3.
we'll probably indeed implement in a future version to also upload the .cdg
in the meanwhile, a workaround would be to zip your mp3 and cdg in one file, so that clouddrive will upload the .zip (but I understand if you have many files this is not going to be feasible)
geposted Fri 05 Apr 24 @ 6:45 am
Hi, I'm having a similar problem here whereby my uploads are karaoke tracks, the vast majority being zip files, and they are appearing in the clouddrive folders as songs and, when loaded onto a deck, they appear as an unknown filetype.
geposted Mon 15 Apr 24 @ 7:09 pm
