Topic: BPM increasing
I'm finding tracks' BPM's are increasing (by 3-5 bpm) once loaded onto a deck, I have to adjust to the correct BPM with the pitch fader. Anybody had/have this problem?
geposted Mon 08 Apr 24 @ 1:01 pm
It's most likely the autoMatchBpm feature that is enabled
Here are all the auto options explained, so you can figure out which ones you want to use:
Thanks Klaus, but automatchbpm is already disabled.
Tracks from where? Are you using a streaming service, or playing purchased files from your hard drive?
Files from a streaming service are populated with metadata automatically from some unkown online source (presumably because analysing stream files is now painfully slow) but the "cloud" analysis is not always accurate - so you will find that the BPM often changes once the track is loaded and analysed by VDJ.
Even purchased files, depending on where they're from, can have incorrect BPM data.
How are you determining that the BPM when loaded is "wrong"? Compared to what?
