Topic: The display of the Sampler is strange
There is no indication of the air horn that should have been in the sampler on the pad, and it no longer works.
Also, when the crossbar is turned to the left, the sound of the sampler is not heard. Help me.
geposted Sat 13 Apr 24 @ 1:45 am
Are you sure you have selected the correct sample group, and that it has less than 8 samples for it to be shown on both decks?
For sampler output channel - and thereby if it should be affected by your faders - change that in the dot menu on the sample pane
geposted Sat 13 Apr 24 @ 5:34 am
Thank you for your reply. As you can see in the attached photo, there is a full range of Mr./Ms. fans on the right deck, but there is only "laugh" on the left deck.
geposted Sat 13 Apr 24 @ 10:00 am
