Topic: Prepared stems
Hi everyone,
I prepared the stems with a high-performance computer so I could then move them to my secondary Macbook which is very dated. All the folders and file names are identical on the two computers, I copied the prepared stems into the various folders and I must say that 90% of them work perfectly while a few scattered ones don't work. What could be the reason? If I recalculate them even with the dated MacBook then they work.
Another question, is there a way to deactivate prepared stems? What if I don't want to use them when I load the track?
Thank you
geposted Sat 13 Apr 24 @ 1:52 pm
Find a solution bro?
