Topic: Channel Fader Reasign
On My DDJ-1000 the faders for Decks 1,2 stopped working Like to remap the to 3,4 but can't seem to find the options to do so. In Mapping there is no Deck option to do 1,3,4,2 so not sure how to do this or am I stuck just having to buy a new controller.. Please Help
geposted Tue 16 Apr 24 @ 12:02 am
Change the "mixerOrder" setting
Still, if you switch it to 1234 instead of 3124, the second physical channel that's faulty, will still have to be used (only that now it will control deck 2 instead of deck 1)
geposted Tue 16 Apr 24 @ 8:17 pm
One solution that may work, is to mod the mapping for "VOLUME" key to :
var '$DDJ1K_HID' ? nothing : level
To:
var '$DDJ1K_HID' ? nothing : action_deck 1 ? deck 3 level : action_deck 2 ? deck 4 level : action_deck 3 ? deck 1 level : action_deck 4 ? deck 2 level : nothing
I do not have the DDJ 1000 to test, if using the above script to swap volume faders, as you wish, will be successful.
geposted Wed 17 Apr 24 @ 6:03 am
