Just updated to VirtualDJ v2024-m b8095 and it seems very laggy. I can notice it in the waveforms as they scroll across the screen. Seems to jump every second or so and makes mixing and beat matching more challenging.
If a song name is scrolling side to side because it's too long to show the full name in a playlist view, it's also lagging every second at the same time it's happening to the waveform.
Seems to be the full app is just laggy. Happening to anyone else?
geposted Tue 16 Apr 24 @ 1:19 am
Hi Pierce,
I saw the same laggy waveform on the same vdj version on Windows 10. The waveform seemed to be moving ~20fps or so with visible jumping. I double checked the skin fps setting and my monitor fps. The issue still persisted after restarting vdj. I can't remember if I tried restarting my computer.
Unfortunately I've since uninstalled and reinstalled while debugging another issue and am not having any visual glitches. Sorry I can't offer more input, just wanted to say I saw it too.
geposted Tue 16 Apr 24 @ 3:28 am
zero perfomance issues here but i run pc and an RTX card on this machine.
dunno what to tell ya except maybe post FULL computer specs - processor, graphics card, RAM, controller, what else is going on at the time on the computer, etc...so they can do some real troubleshooting.
just saying its' 'laggy' doesn't give much to go on because lots of things can cause that and not all of them software related.
geposted Tue 16 Apr 24 @ 5:56 am
I'm having as well very laggy waveforms with b8350.
Any solution?
Apple macbook air 2024 M3 16GB RAM
Any solution?
geposted Thu 07 Nov 24 @ 5:17 pm
Hello Vdj I’m having the same issue with laggy also I just bought a new laptop and it’s i9 intel RTX 4060 32Ram and 1t ssd storage and I am still having stupid lagging loading a song. You recommend us using the highest quality laptops that cost a lot and we still have a stupid lagg on stems . Like come on do something about this please. I’m not satisfied with this software. I really like vdj but this can’t be happening it’s 2025 please give us an update for better performance.
geposted Thu 29 May 25 @ 1:03 am
I’m also having the same issue now , never had it before up until the devs started adding new updates. I havent updated it for almost a year and it worked fine up until i factory resetted my pc and now that i downloaded vdj again its only been laggy.
geposted Sat 20 Sep 25 @ 11:47 am
