Topic: getting the album art to appear again
hh73PRO InfinityMember since 2006
above the tracklist. the records are missing. is there something i turned off?
geposted Mon 22 Apr 24 @ 11:16 am
oh im using sidelist for the first time. does that prevent the album art from showing? mean screen estate.
geposted Mon 22 Apr 24 @ 11:31 am
In VirtualDJ Settings->OPTIONS, make sure the coverFlow is not set to No
If not set to No and still dont get it, maybe it's resized to zero, so try to put your mouse above the line that separates File List and Search bat and you ll get the double-arrow mouse pointer to resize
geposted Mon 22 Apr 24 @ 11:59 am
more space now. and yes that option is turned off. hmm
geposted Mon 22 Apr 24 @ 12:17 pm
its not a deal breaker. but kinda liked it
geposted Mon 22 Apr 24 @ 12:51 pm
So turn it back on? :p
geposted Mon 22 Apr 24 @ 12:54 pm
nope. :(
geposted Mon 22 Apr 24 @ 1:01 pm
If you don't turn it on, you won't get the album art.
geposted Mon 22 Apr 24 @ 2:43 pm
going to do a full re install of vdj. which isnt a big deal. only things i had odd this week were a new nvidia driver set my monitor to 4k. and a new driver. when i set things back to 1140p. little stuff was missing.
geposted Tue 23 Apr 24 @ 7:25 am
yep seems to be fine now. sometimes a re instill will work. i must have closed/pinched some windows and hide the album art.
geposted Tue 23 Apr 24 @ 7:45 am
