Topic: Hot Cue Behavior
I've noticed while messing around that the slip point seems to move when I have it enabled, press and hold a hot cue and press another hot cue. This seems to cause the slip position to move to the first hot cue's current position. I don't know if this is on purpose or a bug, but how would I make it so a hot cue will stay playing until another one is pressed, say for example, if I want to rearrange the instrumental with hot cue points while slip holds the track's actual place, so I can return to the original instrumental when I want otherwise?
geposted Thu 25 Apr 24 @ 2:03 am
not really a bug just what it does, when slipmode is on pressing a hotcue makes a note of where it is at that time, it goes to the cue and when released it returns to position + time passed.
So your 2nd press is saving the position as the go back to point.
In some ways it could be seen a feature [desired behaviour, pressing 2 buttons at the same time is either on purpose and you want the slip return updated, or it's a mistake and you didn't mean to press 2 buttons at once]
That said, when you're mashing pads mistakes happen
You can dance round it with something like this
get_slip_active ? get_slip_time & param_cast ms & goto & hot_cue 1 : hot_cue 1
geposted Thu 25 Apr 24 @ 3:23 am
