Topic: Sudden weird behaviour never experienced before
Two hours in gig something really weird happened which never experienced before.
I run VDJ build 7831.2028 together with a XDJ-RX3. Everything has worked fine up to this point.
A track was playing on deck 2, audio normal and waveforms ok on VDJ skin.
When I was about to CUE a new track to deck 1, I could not hear deck 1 in the headphones. Deck 2 was still ok.
Memory is a bit fuzzy but I also think I could hear deck 2's track in the headphones even if no cue button was pressed on the RX3.
There were no track waves visible in the RX3 display from any of the decks.
I could not either control deck 1 from RX3, so track was running out on deck 2, silence for 4 seconds, before I in panic managed to switch over to USB for the rest of the night.
I made some experiments during the gig to switch back to VDJ, but the problem was still there, even after restarting VDJ.
I try to reproduce it today with no success.
geposted Sat 04 May 24 @ 1:13 pm
I think I now understand what was happening
I must have in some way changed to DECK 3 by mistake.....
It's almost impossible to know this has been done, luckily I recorded a video on the RX3 screen where I can see 'Deck3"
This is totally unrelated, but I saw that you use a RX3 with VirtualDj. I am trying to connect my RX3 with virtual DJ but some buttons/effects on my RX3 don't behave the way they should... So my questions is; Did you ran into any problems with some buttons and/or effects not working properly? If not, What are the settings you use? like did you change anything or was it just connect and play? thanks in advance :)
It works perfect for me with no need to change any mapping
