hello.
so, on my tidal library i added albums which show up in the vdj under the liked albums category.
once i select an album, it shows me all it's tracks at first. once i play some and then close and reopen vdj the rest disappears and i don't know how to stop it from doing this.
now, the weird thing is that once i delete the foldercache.xml from the tidal folder inside the vdj cache it goes back to normal but only for the next run of the program.
does anyone have a suggestion on what's going on?
also at some point vdj is stuck on the downloading background task when i get focus on the tidal folder.
geposted Fri 10 May 24 @ 7:03 pm
