I have a number of controllers with ASIO drivers but I have noticed that if I click on the ASIO options button in virtual dj for my SZ, it will cause the software to hang. Reproduced on multiple laptops and I know an obvious work around is "don't do that then" but I thought I should draw attention to this bug as I can access the ASIO options for other controllers from inside the software and even for the SZ it works just fine from the start menu but not from inside virtualdj.
Thoughts?
Thoughts?
geposted Sat 11 May 24 @ 12:31 am
