I’ve done 3 two-hour shows using Virtual DJ and Live365 for 7 years. My Netgear router uses 270 Mbps. During shows, Virtual DJ covers the Auto DJ signal underneath.
Since last Wednesday at the times of the live shows, a little of both streams at the same time, in & out (3-5 seconds each).
Any idea how Virtual DJ gets overcome by 365Live Auto DJ suddenly now? Local server, weather, modem or what? Thanks any help given.
geposted Mon 20 May 24 @ 3:49 pm
Can you connect to the Live server without stopping the auto DJ first?
If so, maybe you had a temporary network glitch, and VirtualDJ auto reconnected as soon as possible
VirtualDJ will try reconnect when there is a small dropout
geposted Mon 20 May 24 @ 3:51 pm
I lately discovered that now it's possible to broadcast directly from VirtualDJ to Mixcloud, having much better sound quality, compared to streaming through OBS. But now a new problem appeared: it looks like VirtualDJ (at least on windows and working with Mixcloud) has no Auto Reconnect: once disconnected (by some reason or because Mixcloud makes a short disconnetion every 4-8 hours) VirtualDj continues showing broadcast activated, but stream does not arrive. To realize that, it's necessary to monitor the broadcast via internet on Mixcloud. (To realize the disconnection and for quickly be able to reconnect by hand, the stream has to be listened - the price are many seconds of latency - and if the reaction takes some minutes, even the monitor-browser does not reconnect and also has to reload the complete site by hand and around at least 1 minute of break are inevitable... Can this really be a serious option for anybody?).
Mixcloud is telling on their FAQ: "If you're planning an extended stream, we recommend making sure that your streaming software is configured to automatically reconnect."
If VDJ really doesn't have Auto Reconnection, I beg the programmers of VDJ to solve this, please, at least for Mixcloud. Even the freeware is able to (in OBS it's an option and working well). If it's just a bug happening to Mixcloud or Windows, now you should know it.
But I yet don't know, if there's a wanted reason, if it will be repaired, how long it would need or if I just was too unable.
So my question: Did anybody have same problem and found a solution to let VDJ auto-reconnect the broadcast to Mixcloud in some way?
geposted Thu 24 Oct 24 @ 8:01 am
In my case (streaming to mixcloud) there is no auto reconnection working in VDJ.
geposted Sat 26 Oct 24 @ 5:53 pm
