Topic: CloudDrive - stems and downloaded files
Hi! I have two questions about CloudDrive:
1) If I upload MP3 files I own to a CloudDrive folder (currently using OneDrive), it doesn't seem to give me an option to prepare and save stems, is this something that is possible to do?
2) In the FAQ (https://www.virtualdj.com/forums/257771/General_Discussion/VirtualDJ_2024__CloudDrive_FAQ.html) it states that if I want to have the files stored locally, I'd have to drag them to a local folder. If I do that, will the lists saved to CloudDrive automatically recognize the file's stored locally, or would I have to manually create/rebuild the lists with the local files?
geposted Thu 20 Jun 24 @ 3:53 pm
Is there anyway to prep stems on one computer and access the prepped stems on another ideally with the cloud drive this would be greatly helpful as my backup computer is very slow at prepping stems
I prep my ones on my home machine and copy them to the gig machine by syncing with a Samsung SSD. Not sure if it's possible in the cloud but you can copy stems from one machine to another.
