Topic: Audio Output Distortion
Using current Mac OS, latest Version of Virtual DJ, 2 Issues still are naggingly annoying...
1). - fresh OS boot, first run of VirtualDJ, after playing one or two tracks if the BPM has been changed I get a serious Squeekling Audio Distortion Mid to High end on all subsequently loaded tracks...
Have to close and reopen Virtual DJ to clear and it doesnt seen to happen again during that session...
2) still issues with "iPhone Remote". its better BUT, occasionally if I have to switch apps on the iPhone for a while to check something else the VirtualDJ GUI locks and nothin responds to Mouse clicks, although Playback continues to the end of the current track, bring the remote app back to foreground and response on the desktop is OK.
Still issues with Remote app :- must set "NO Lock" display in settings (on the iPhone) otherwise app crashes and it usually only connects to VirtualDJ properly if the Remote app is running on the iPhone BEFORE the desktop App is started - otherwise the remote app appears to connect and then crashes...
geposted Tue 25 Jun 24 @ 10:11 am
