Topic: Frozen Virtual DJ
I have a Mac Pro (I checked w/apple and run diagnostics and its perfect) and using Virtual DJ on Saturday it froze 3 times with the rainbow circle. I either need to uninstall and reinstall. VIrtual DJ says I could reset. What do you suggest so that I dont loose anything. If anyone is an expert please asist me.
geposted Wed 26 Jun 24 @ 3:41 pm
Hi,
Might be simpler for you but I had an issue with karaoke/video making VDJ screen really laggy and unresponsive on macbook air m1, nothing I tried worked ended up having to reformat laptop in the end which is the only thing that resolved the problem.
Hopefully someone else on here has an answer so it doesn't come to that cause its a right pain but just be aware it might be your only option.
