Topic: backspin jog wheel volume
hello everyone when i backspin with the jog wheel the volume seems to be too loud and its annoying everytime i lower the volume before i backspin or i use low pass filter does anyone have a solution about it ? thank you !
geposted Fri 26 Jul 24 @ 2:26 am
Backspins (in real turntables) behave the same way... since the velocity of the vinyl under the needle is initially higher, the volume is higher as well.
VirtualDJ just applies the same physics.
geposted Fri 26 Jul 24 @ 7:01 am
