Hello!
I have noticed that in some locations, if the subwoofer is too close to the DDJ1000, while the song is playing on one deck and the next song is paused with the loop on the other deck, the selected loop jumps to the beat of the music that is playing. This also causes random music to freeze for seconds, freezes the controller too, and then works all over again as soon as I remove the loop.
How much should I raise the jog vibration protection in VDJ from 0? Or should I put a sponge under the DDJ instead? I think I've experienced this since I switched from windows notebook to macbook air m2 (512ssd,8gb ram) and use realtime stems 2.0.
Thank you very much for your answers! Chers
geposted Tue 06 Aug 24 @ 9:24 am
This is a known issue of DDJ-1000 and it's actually the reason that jogvibrationprotection setting was introduced.
There's no "global" solution. Try to raise the value until you no longer have issues, but you can also use the jog as desired.
geposted Tue 06 Aug 24 @ 1:27 pm
Thank you! I will try to fix it!
geposted Tue 06 Aug 24 @ 1:48 pm
What does this setting do exactly?
geposted 3 hours ago
