Recently I have noticed that when I go into the BPM editor for tracks that are set to "Multiple BPM", if I select any beatgrid anchor (except the first one) and then use "BPM Shift" to adjust the beat position in the grid, it retains this while I am using Virtual DJ, but after closing and restarting Virtual DJ the changes have gone and I am back to the original grid analysis.
If I click on a beatgrid anchor, select the check box "1 of 4" then move the anchor to the 1st beat position then it does seem to keep the setting however if the track has irregular phrasing I have been using the BPM editor to go back or forward the required beats (4 or 8 etc) so that the 'Phrase Sync' wheel stays correct, I can't get that to retain, it will work during the current session no matter how many times I load the song, then revert back the next time virtual dj loads.
Am I using the BPM editor wrong as I am sure this used to work.
geposted Sun 11 Aug 24 @ 2:19 pm
