Topic: virtual dj analyze songs
Why doesn't Virtual DJ Analyze my songs? I have the option checked that says do it on view. It does a couple songs then just stops.
geposted Wed 14 Aug 24 @ 1:05 am
You've not given enough info. Songs from where?
If they're from a streaming service then a delay is normal (and they're not your songs).
Songs that I have saved on my hard drive.
I think I have to create a playlist or something because right now I just have my songs saved in folders on my PC.
Read the user guide. It explains how to add so gs to the database and analyse them.
Ok thanks
