Topic: Tidal Error: Download Error
Tidal has recently stopped working and any time I load in a song from Tidal it just shows Download Error (Requested Quality is not allowed in user's supbscription).
I have tried everything, logging out and back in, reinstalling vdj, changing the streaming quality from lossless to high, nothing worked!
I don't know if it has something to do with the vdj version I'm using (b7607, 2023). I've stayed on that version because I could still use stems with Tidal songs on that ver.
Does somebody know what is causing the problem. Thx for the help.
geposted Fri 23 Aug 24 @ 1:11 pm
Since May 2024, Tidal has required a DJ extension to the normal subscription, in order to work with DJ equipment. With this extension, stems can be used and also you can download tracks to cache for offline use.
The DJ extension is applied on top of the individual subscription.
https://tidal.com/djs
geposted Fri 23 Aug 24 @ 1:17 pm
yes, but you cant record, shame for tidal !
only need more money !
Moderator It is a reasonable limitation that all subscription services require.
geposted Fri 06 Sep 24 @ 1:05 pm
