Purchased new laptop. Trying to copy my VirtualDJ folder from Documents to new pc.
i do that all is good but it will not seem to import my database or filters, mylists etc. Looking for help.
geposted Fri 20 Sep 24 @ 11:05 pm
likely your new install set your home folder to the new location
.../app data/
check by clicking cog as shown in picture, place you files where vdj says the home folder is
geposted Fri 20 Sep 24 @ 11:17 pm
when the hell did it move to app data lol.
How do I change the home Directory back to VirtualDJ is documents. the AppData will confuse me.
Edit: Found a post to sort it! Woot!
https://www.virtualdj.com/forums/225732/General_Discussion/Change_Default_Location_of__VirtualDJ__System_Folder_(v8_on_a_PC).html
geposted Fri 20 Sep 24 @ 11:27 pm
