Topic: FLX10 Trim not working
Hi,
I just downloaded VDJ for FLX10, connected and tried to check it out. I find that the Trim knobs do not control the output, and the output is peaking all the time. I checked the manual and could not find any fix for this. Is this normal behavior or is there a fix? Thanks!
geposted Thu 03 Oct 24 @ 9:55 pm
I found the issue. I had enabled Stems for eq knobs. Looks like Trim knob also controls the stems in this case.
