Topic: Citronic mpx10
Hi everyone.
I have acquired a citronic mpx 10 controller in mint condition.
I have done some mapping etc, but am struggling with the ONINIT setting.
I set the ONINIT volumes to zero, and saved etc.
Then each time I turn VDJ back on I have to re-do it all again.
Am I doing something wrong ?
I would really appreciate any advice.
Many thanks in advance.
Ray
geposted Mon 07 Oct 24 @ 10:41 am
So what is the action you have set the ONINIT key to ?
Is it the ONINIT key of your Controller Mapping or Keyboard ?
Instead of zero, you get Full (100%) or some other position related the actual faders on the Controller ?
Hi DJDAD, it's for when I connect controller, I don't want the faders coming on at full volume.
I was lead to believe if you set the ONINIT levels to 0% and save, then it would stop levels coming on at full volume.
