It would be nice if there was a way to have folders in the My Lists section so we can keep the lists in folders like it used to be with playlists. I had to use an external browser to get the folders, but at least they showed up and I could keep the lists grouped and organized. I have many lists and My Lists is wayyyyy to long.
geposted Tue 08 Oct 24 @ 8:20 pm
Lists can serve as folders as well - I use list folders to organize lists for the same reason you described (you just drag those lists you want to group into another list)
geposted Tue 08 Oct 24 @ 9:14 pm
How do the lists in My List serve as folders? The lists in My Lists only house songs and not other lists. I am not able to drag and drop a list into another list. The lists only move around the browser section and don't go into any folder that I see.
geposted Tue 08 Oct 24 @ 9:27 pm
I'm pretty sure lists can contain other lists as well as songs:
It may be a bit finnicky to get done right with the drag functionality, but all you have to do is drag the list into the folder you want to contain it - you'll see the red drag indicator line change to have an arrow on the left hand side, indicating that it will be nested into the list you dragged it onto.
Note: this doesn't happen if you have lockFolderOrder set to yes. Set it to no to allow the dragging of folders.
geposted Tue 08 Oct 24 @ 10:39 pm
Yes, I use sub folders all the time;
geposted Tue 08 Oct 24 @ 11:46 pm
Thanks for your help. If i drag the folder all the way to the left, it shows a "move to" option. it was a bit tricky but at least it works! :)
geposted Wed 09 Oct 24 @ 12:15 am
