Hey Guys,
did someone already tried this & whats to share there mapping?
Can someone explain to me what command i need to give for fx effects?
thank you
thank you
geposted Wed 09 Oct 24 @ 11:08 am
MKI or MKII?
Either case hasn't been defined or mapped.
Without a definition file you can only get simple midi into vdj [no led feedpack]
commands are just the same as all other cases
deck 1 effect_active echo
deck 1 effect_slider 1 1
deck 1 effect_slider echo 2
I've yet to find a midi table for it, but it could be defined depending on how much you want LED feedback.
geposted Wed 09 Oct 24 @ 11:35 am
There's this PDF for the MK2
geposted Wed 09 Oct 24 @ 11:46 am
Thanks, looks straight forward enough.
geposted Wed 09 Oct 24 @ 12:11 pm
already thans for youre feedback.
it's MK1 that i have.
I have a FLX10, but would like to have more fx control & pad control, that's why i wanna try to use my Akai device. Will try those fx commands. Bad to see you can toggle lights on/off
geposted Wed 09 Oct 24 @ 12:23 pm
I have requested from AKAI the MIDI Communication Protocol for the MK1 (could be available online somewhere , but was unable to find). Once i have this, we will create the definition file and will be relatively easy from there to create your own Mapping with all buttons, knobs and leds.
geposted Wed 09 Oct 24 @ 2:01 pm
Hey DJDad, thank you, looking forward!
geposted Fri 11 Oct 24 @ 6:16 am
