I costumised a shortcut to show similar music if I press the key on a selected titel. That works fine, but it would be much better if the similar music would always be showed on any selected titel in the sideview.
Does anybody have an idea or the code to do that?
geposted Sat 12 Oct 24 @ 9:49 am
geposted Sat 12 Oct 24 @ 9:53 am
Thanks for your help. But it seems not to work properly. If I select a titel and do a right click on it, then choose "search similar.." I get an result. The sidewiew "similar songs" shows nothing. Is there a way to configure the search parameters? So that it only searches for same interpret and titel and nothing more?
I configured the sideview to look for local files.
What I want is for example: I select a song in the browser of an online Music folder, than the sideview "similar songs" should show me the local songs with the same interpret and titel.
geposted Sat 12 Oct 24 @ 11:00 am
geposted Sat 12 Oct 24 @ 11:08 am
If you select 'Alternative Remixes' and 'Local', it should update after selecting a new song in the browser automatically.
geposted Sat 12 Oct 24 @ 11:56 am
I did that and it updates, but shows online content only and nothing of my local music. Similar songs (local) just shows nothing.
geposted Sat 12 Oct 24 @ 12:04 pm
I have the same problem. The local function doesn't show anything at all.
geposted Sat 29 Mar 25 @ 11:02 am
Same. worked fine untill a update maybe two month ago, which is also when i started messing with my configs a bit mutch, so not really sure if pebcak or bug.
Any logs or something that might be of value?
geposted Sun 10 May 26 @ 1:22 am
