Topic: Any easy way to relocate missing file?
Are there any easy way to relocate missing files in my saved playlists when I have moved files around and switch location where they was stored or when I import an old playlist?
Now it I have to relocate every single file and find where they are now.
Take so mush time.
Rekordbox have a perfect solution for this and can automatic find where it is on the harddrive.
Does VDJ have this solution anywhere or a simular function?
Also:
Are there a easy way to replace a deleted file in a playlist when I replaced it with another version of it.
Exampel search other version of the song thats missing
geposted Mon 14 Oct 24 @ 8:23 am
Select all files, then do relocate
